Pressurizing and sealing gas springs
Amir Sedieqy
Military
Aug 11, 2020
10
Prior to testing and probably painting, the last stage of manufacturing a gas spring or gas strut is pressurizing with Nitrogen. I was wondering how this step is done. I think it is filled with gas from the rod side and the rod seal works as an one way path, meaning, nitrogen gas is injected into the cylinder with certain amount of pressure, and then when the injection is stopped, the pressurized nitrogen in the cylinder pushes the seal back and seals the gas strut, but I’m not sure.
