PREVIEW
dan14
13
HI YOU ALL!
I USE PRO/E 2001. MAY I DO PREVIEW MY FILES BEFORE
OPENING, LIKE IN AUTOCAD.
Greetings,
In the lower right corner of the open file dialog box there is a "PREVEIW" macro. After highliting a part name, enable the Preveiw macro and a window will appear displaying the part geometry--without first launching. However, I have found that if the part is created in any other version than the one you are currently using, (2001 vs 200i2) the part will not display in the preview window.
I hope this helps.
