DriveMeNuts
If an attachment to a vessel has a sustained "load controlled" gravity type load that causes Pl+Pb in the shell to be just below Yield then plastic collapse will not occur and therefore this is acceptable. (Say this sustained load causes a deflection of the attachment from zero to 5mm.)
If the same attachment while having the sustained gravity load on it also has a displacement caused by expanding pipe work which has a displacement range between zero and 10mm. As the PL+Pb+Q across the displacement range is slightly less than two times yield, plastic deformation in the first cycle will occur as will shakedown, therefore this is also acceptable.
For the 10mm piping displacement to be considered as a "strain controlled" load, does the piping it need to be fastened to the bracket?
If the piping is not fastened to the bracket, then the piping is more like a "pusher" moving between zero and 10mm, coming into and out of contact with the bracket during each cycle.
If the stresses around the bracket are already close to yield with a gravity load and then a non-fastened "pusher" displaces the bracket further, are the stresses associated with the pusher displacement still Secondary, or do they become Primary because the pusher does not provide the bracket with a returning displacement?
Is it possible for the shell local to the bracket to plastically collapse if the piping is not fastened to the bracket as described above?
