Buildtech2
Currently, I am assessing the old primary secondary chilled water system. The system has 2 duty and 1 standby chillers with constant primary and variable secondary pumping system with a decouple pipe. the secondary pumping system is serving chilled water to total 10 low rise and high rise towers and this system is dedicated for only IT rooms in all towers. I have noticed that secondary pumping system is being controlled by a common DP sensor and it is apparent that a single DP sensor cannot be used for supplying chilled water for all 10 towers because we cannot assure all the cooling coils can receive design chilled water flow. Therefore, I would like to recommend that each tower shall be provided with a separate tertiary pumping system with its own DP sensor for enhanced control and adequately supplying the chilled water. Appreciate if anybody can put their valuable thoughts.
