Frankie183
- Jun 25, 2020
- 22
I'm trying to print the displacement of one particular node in the .dat file.
I've used *node print and also *node print, Nset = picked_nodeset, I placed the lines just above the *end step, however then I get the error that:
'THE INDEPENDENT VARIABLES MUST BE ARRANGED IN ASCENDING ORDER. THIS ERROR MAY HAVE BEEN CAUSED BY A POSSIBLE EMPTY LINE ON THE DATACARDS IN THE PROPERTY DEFINITION.'
Any ideas on how to get the displacement output in the data file?
Greetings,
Greetings,
