Print Stamp 1
vava1
30
Hello, I have tried using the printstamp command to stamp the folder and file name with date on my drawing but cannot get it print out as text or be viewed on the drawing? Any help on how to perform this procedure correctly will be appreciated!  Thank you very much.
Is it possible that you don't have the parameters correct on here? There are quite a few steps to making the printstamp show up correctly. First you have to have the print stamp box checked in the print screen, then Additional options window. Then type Print Stamp in the command line, and set the parameters. If you are at all unsure of what the options are it will say in the help options.
As far as size location etc, I usually have my text size at around .125" and the offset of the text from the edge at ".2,.2". Have it set to the BL corner. Hope this helps.
