RSilva
- Jun 23, 2017
- 35
Hello
On my work, we have CATIA V26, Pro E and NX 11 and, when i receive STEPs from CATIA, sometimes the solids open.
When i have alot openings i ask to the people of Pro E to just import and export that STEP, after that i have much less openings.
One of the big problems are the tubes, i uploaded 2 images where i show the diference between STEP coming from CATIA and the same STEP after be imported and exported from Pro E.
When i import the STEP coming directly from CATIA, NX divide the tubes, and some times, half of that tube disappear as you can see in the attachment on yellow tube with an arrow;
When i import the same STEP after be imported and exported from Pro E, the tubes dont divide and i dont have any openings on tubes.
I only wanted import STEPs without always asking Pro E to import and export.
There are any option on NX, that i have active, that open the solid so much or at least that divide the tubes?
I attach another image just to show what i have when half or all tube disappear, other tube appear outside of the solid as you can see on this image.
Best Regards
Rúben Silva
Best Regards
Rúben Silva
