Breadmon1818
Bioengineer
Hi Forum, I have a very simple model representing a ball and socket. I aim to simulate internal socket movement by placing the ball and socket in contact and then adding a small displacement to the ball to create a stress distribution in both rudiments, followed by a rotation of the ball about its center point.
(A frictionless, "Hard Contact" surface-to-surface contact interaction is used between the outer surface of the ball and the inner surface of the socket. The simplified socket is fixed on its top (distal end) and on its sides).
Unfortunately, when rotating the ball about its center a constraint is needed (I've used coupling primarily but have tried MPC, Tie, and others) which then considers the ball rudiment as a rigid body. With this constraint, rotation is achieved, however, no stresses are developed for the ball rudiment ... the developed stresses are what I am aiming to find/use for continued analysis.
I've read the theory behind these constraints and am aware that constraining a surface, node(s), or geometry to a specific reference point (in my case the center of the ball rudiment) means that the moments/forces/stresses of the reference point will be distributed to that of the constrained surfaces/nodes, etc.
This explains why the ball rudiment acts as a rigid body and thus no stresses occur, but is there any way around this issue?
Is there a way to achieve the same rotation about the center of the ball (in a rotational BC) without making the ball rudiment rigid?
