anto_772
- Jul 19, 2018
- 7
Hi guys, I'm trying to run a lightning strike simulation over a curve composite plate. I've done a previous simulation over a composite planar plate and I obtained good results.
The thing is, when I introduce the same boundary conditions, load and material as the planar plate in the curve model, I only obtain a plot of the electrical potential field, without receiving any temperaure plot (temperature remain as the initial temperature condition I introduced in the model --> 25 ºC).
Does anybody know what could be happening? As I said, in the planar plate model, I obtain good results, the only thing that has changed is the geometry for the curve plate model.
Thanks for the help!!
