Hello, good morning,
I am working as a project engineer on an evaporative crystallization process, at pilot plant level, which uses a vacuum pump to promote evaporation of water at lower temperature etc.
The problem is that the vacuum is not generated because the round lid of the crystallizer is divided into 2 parts and has a large hole through which the agitator shaft passes. Is there any material, glue or mechanical seal that allows the equipment to operate as is?
The other option is basically to have a one-piece cover made with the hole just with the external diameter of the agitator shaft.
I remain attentive, and thank you very much!
