adrich91
Chemical
- Oct 6, 2024
- 5
Hello colleagues!
Today I'm here again to get some help with some issues I have in my head.
First of all: I hear a lot the expression ‘to clean with water with pressure on something’ and I suppose that it is not really pressure that is being talked about, but a lot of flow, isn't it? Because I understand that it is a lot of flow that makes water come out at high speed and it seems that ‘it has pressure’, right? No sense to talk pressure with fluids...
Second: In many processes, after passing liquid from one tank to another, a nitrogen sweep is made to push the excess liquid in the pipes to the final tank. If I have N2 at a pressure of 7 bar, I understand that it is like making a balance between initial point and final point applying the bernouilli theorem where the initial pressure is the pressure of the N2 and the final pressure is the pressure in the final tank, right? I need to make a calculation depending on the pressure drop, fluid...etc to know what N2 pressure I have to apply to overcome the pressure drop and drag the liquid, right?
Finally, third doubt. I would like to know if there is any program at a visual level that you can draw a pump, pipes, tanks and you can move the fluid and see how it behaves, either at a professional level with real data of head losses to be able to possible preferential paths in a pumping system or even if it is only visual for presentations and basic explanations.
Thank you very much, best regards and sorry for my english
