Program to change face color
mery0
Automotive
Nov 15, 2023
I want to create a program that lets the user select faces and then changes the selected faces to the color we specified.
Also, the selection is limited to faces.
Please let me know if you know.
Hey, I just saw your request. If you haven't found it already, here’s my approach. I hope this is what you're looking for:
Code:
' Written by TW
' Journal desciption: Alters the color of selected faces. Has priority over the main Material Journal. Used to distinguish the inside/outside of the body.
' Shared on NXJournaling.com
' Written in VB.Net
' Tested on Siemens NX 2212 and 2306, Native and Teamcenter 13
' V100 - Initial Release - November 2023
' V101 - Configuration Settings
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
    Dim theSession As Session = Session.GetSession()
    Dim theUfSession As UFSession = UFSession.GetUFSession()
    Dim theUI As UI = UI.GetUI()
    Dim lw As ListingWindow = theSession.ListingWindow
    ' Configuration Settings:
    ' Face Settings:
    Dim facecolor As Double = 17 ' Set the face color to ID: 17
    Dim facename As String = "Inside"
    Sub Main()
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Face Color")
        Dim selobj As NXObject
        Dim type As Integer
        Dim subtype As Integer
        Dim theFaces As New List(Of Face)
        Dim numsel As Integer = theUI.SelectionManager.GetNumSelectedObjects()
        ' Process the preselected Faces
        If numsel > 0 Then
            For inx As Integer = 0 To numsel - 1
                selobj = theUI.SelectionManager.GetSelectedTaggedObject(inx)
                theUfSession.Obj.AskTypeAndSubtype(selobj.Tag, type, subtype)
                If type = UFConstants.UF_solid_type Then
                    theFaces.Add(selobj)
                End If
            Next
        Else
            ' Prompt to select Faces
            If SelectFaces("Select Faces to change color", theFaces) = Selection.Response.Cancel Then
                Return
            End If
        End If
        For Each temp As Face In theFaces
            Dim displayModification As DisplayModification = theSession.DisplayManager.NewDisplayModification()
            With displayModification
                ' .ApplyToAllFaces = False
                .ApplyToOwningParts = True
                .NewColor = facecolor
                .Apply({temp})
            End With
            displayModification.Dispose()
        Next
    End Sub
    Function SelectFaces(ByVal prompt As String, ByRef selFace As List(Of Face)) As Selection.Response
        Dim title As String = ("Select Faces - " & facename)
        Dim includeFeatures As Boolean = False
        Dim keepHighlighted As Boolean = False
        Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
        Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart
        Dim selectionMask_array(0) As Selection.MaskTriple
        Dim selObj() As TaggedObject
        With selectionMask_array(0)
            .Type = UFConstants.UF_solid_type
            .Subtype = 0
            .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_ANY_FACE
        End With
        Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObjects(prompt,
        title, scope, selAction,
        includeFeatures, keepHighlighted, selectionMask_array, selObj)
        If resp = Selection.Response.Ok Then
            For Each temp As TaggedObject In selObj
                selFace.Add(temp)
            Next
            Return Selection.Response.Ok
        Else
            Return Selection.Response.Cancel
        End If
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
