GBMRAO
- Sep 4, 2018
- 31
HI Friends,
I am currently analyzing a building for progressive collapse. The m factors and an increased load is suggested to be placed on the floors. I was wondering if the first option "a" satisfies then is it ok or do we have to check both of them both a and b lines. why is there "c other" interpolation of web slenderness will still result in a higher value from flange slenderness. so it's obvious to use flange slenderness. unless i am missing or misunderstood.
IF i have three floor and the first-floor column is removed. we calculate the M value for all three-floor beams. But do we have to use the least m value out of all 3-floor beams or each floor has its own m value and corresponding GLF has to be applied to each floor with its respective increased loads. some times each floor may have different live loads.
