Hello all,
For Protection Against Local Failure, ASME Sec VIII Div 2 has two methods. The less recommend one is using "Elastic Analysis Method" that I am using. My question is regarding the Weld Joint Efficiency.
My design is based on ASME B31.4 so I am using the concept of API 597 for the factors. API 597 has a section to explain what to do for "Treatment of the Weld Joint Efficiency" on Protection Against Plastic Collapse.
But it does not say how to treat weld joint efficiency for other failure modes such as Local Failure. The elastic criteria for local failure is that (s1+s2+S3)<4s. Should I consider Weld Joint Efficiency when calculating S or just ignore it?
