Bill3752
Chemical
- Jan 24, 2008
- 138
I am a bit stumped about handling this system. See attached. At blocked in relief (900 psig), the flow to the system will cease, but before that happens the loop pressure will increase substantially. This will cause the suction pressure to the compressor to increase, ultimately causing the RV to lift. Under normal conditions about 90% of the flow is recycled through the cooler.
I suspect I am missing something simple. Any help would be appreciated.
