SA07
- Feb 22, 2018
- 371
Hi
We have several soft starters driving pumps & fans ( 132 kW, 350 kW) which are protected by fuses. Is it possible to replace the fuses with a motor circuit breaker? We had some cases of burnt motor. There is a bypass contactor with each soft starter. Supply voltage is 3ph 690vac .Thks
