Recently, a few clients have requested items that we are replacing (nozzles, flanges, etc) be post weld heat treated. However, the vessel wasn't originally post weld heat treated. This is usually requested due to improved corrosion resistance.
Given that "Examples of Alterations" found in the NBIC, part 3.4.4 (k) states "Performing post weld heat treatment where none was originally performed on the pressure retaining item", this would qualify as an alteration. Calculation-wise, there is no difference in mechanical capabilities (thin walled vessels/nozzles), other that a potential drop in MDMT, but that's not what the clients are after.
As such, how do I go about proving code compliance or mechanical integrity of said alteration to my AI? Interestingly enough, several of the AIs we use aren't sure either.
Thank you.
Thank you.
