proximity sensing
kfas
Student
Mar 25, 2021
I need help to convert the following derivative integration pseudocode for proximity sensing to a matlab program
X[i-1] = X[0]
I[i-1] = 0
Loop1:
D = X - X[i-1]
Is (ABS(D) greater than DT)?
true:
I = I[i-1] + D
else:
I = I[i-1]
Is (I H/d)
true:
Object detected
I[i-1] = I
else:
Object not detected
I[i-1] = I*L
What have you come up with so far? Where does it break?
Dan - Owner
Your pseudocode, as shown here, has typos in. Also believe it or not some idea of what the varibales are would help.
Cheers
Greg Locock
I did zero verification if the algorithm itself was of any use... I just expect to see some work on the part of the student before offering feedback. I didn't see that here, just a cut and paste from a datasheet. Not attempt to actually code it, or show errors in trying to run said code.
Dan - Owner
It is obvious Texas Instruments used it in whatever machine they wanted.From their documentation they could have corrected whatever errors it has.
I didn't say it had errors. i said it didn't seem to perform very well, after about 30 minutes of tuning.
Cheers
Greg Locock
