psi to mph 3
britbrat
5
I have a psi/sec impulse air blast test result that I would like to equate into a MPH wind load - is there an easy formula for this?
A basic formula used to determine wind load on buildings is as follows:
q = 0.00256V^2
q = velocity pressure, psf
V = wind speed, mph
The constant of 0.00256 is a combination of the mass density of air at standard temperature and pressure and dimensions associated with wind speed of mph.
