PSV - Flashing
Chem2020
Chemical
Mar 20, 2012
17
What it means flashing for Psv sizing? How to know fluid would flash?
If the fluid from the PSV outlet has a larger vapor fraction than the fluid from the PSV inlet, there is flasking.
Flashing = vaporizing.
Flashing = boiling.
Good luck,
Latexman
as Latexman suggested it means there is a change of phase liquid->vapor,
you may need to consider HEM or HNE models which are more complex than usual API methods,
you may find a thread discussing these applications with Prode software,
there is an Excel page to do the calc's.
If the PSV discharges to a location where the pressure is less than the vapour pressure of the fluid- it will flash.
e.g. If you're storing a liquid above it's atmospheric boiling point and your PSV discharges to an atmospheric tank- it will flash across the PSV.
As a chem eng/metallurgist the first part of any answer I give starts with "It Depends"
for a PSV flashing you may consider two different models, HEM and HNE,
you will find a detailed discussion of HEM model in API,
these models will predict the amount of vapor and liquid at PSV outlet,
the main difference is that HNE do not condider a homogeneous equilibrium (as HEM) but only a partial change of phase (where the final result depends from inlet conditions),
if you wish to compare HEM and HNE models (plus different variants as HNE-DS etc.) there is a Excel page distributed with Prode Properties Software.
