PSV/PCV flare capacity considerations
Sawsan311
Chemical
AE
Dear All,
I would like to discuss under what scenarios I would need to consider both a flare PCV AND a PSV opened simultaneously and hence need to be consider the combined load in evaluating backpressure hydraulic requirements. Is this scenario eliminated? I have seen in the case of atmospheric tanks being controlled by split range pressure controller acting on inlet and outlet PCVs, that in case of controller failure, the PCV would be widely opened while PSV also popping and hence PSV tail pipe need to consider the flow from both?
Section 5.3.3 in API 521 states that:'' in systems where a PCV is provided, we need not consider its load along with the PSV load as it maintains the pressure below the PSV set point.. '' is this always the case?
thanks
