PSV Question
Lan123
155
Will placing a Pressure sustaining valve on an activated sludge 36" pipeline lead to a maintance headache? I am interested in hearing forum members experience on this.
Thanks in advance.
As long as you use a pressure sustaining valve designed for sewage, you should have no problem.
However, one would expect a valve that size to have significant cost and one would typically design a system so that a pressure sustaining valve would not be required.
