Is there a limit between the PSV set pressure and the operating pressure? For example, if a system was designed with a MAWP of 1000 psig and the safety relief valve has a set pressure of 1000 psig, would this be acceptable if the system operating pressure was reduced to 500 psig? The system is not derated. Is there a limit as to how much lower the normal operating pressure can be below the PSV set pressure?
