Pavan Kumar
Chemical
Hi All,
I have to size a PSV located on the N2 buffer tank. The N2 buffer tank receives N2 from Air Separation plant at 19 bar(g). The vessel operates at 19 bar(g) at 34 Deg C. The vessel is designed per PED 2014/68/EU with a Design pressure of 25 bar(g) at 34 Deg C. The maximum pressure that the vessel can see is 19 bar(g) and there is no applicable scenario. I want some guidance on this PSV should sized. External Fire case is not feasible as there is flammable/combustible in the vicinity. I have seen on some threads on this forum that such cases the PSV can be sized for External Fire Case(even if not feasible) to meet the code requirements. I am have worked with API 520/ 521 standards and can size a PSV for vapor filled vessels for external fire. I want to know the following:
1. How do I size PSV on a vapor/gas filled vessel when there is no credible/applicable scenario, but have to size and install a PSV oer Code requirements.
2. What particular section of PED should I refer to see if a PSV is mandatory on pressure vessels. ASME Sec VIII Div 1 mandates a PSV on pressure vessels.
3. What is the standard in European context that provides formulas for calculate the required relief rates like API 521.
4. Is ISO-4126 the standard that provides sizing formula for vapor sizing of PSVs in European context?.
[URL unfurl="true"]https://res.cloudinary.com/engineering-com/image/upload/v1728505342/tips/Sketch_uw7gxs.pdf[/url]
Any guidance will be very helpful.
Thanks and Regards,
Pavan Kumar
Thanks and Regards,
Pavan Kumar
