WDAG
- Nov 6, 2017
- 21
Hi all,
I'm having some trouble with coordinate systems (not datum CSYS, just CSYS objects). This is the type that I'm talking about: They are generated as part of a script when I use PCB Exchange to import a board and components from the EEs.
I want to snap bodies to these CSYS objects, generally as part of a Move Object. However, if I want to reference them (point-to-point or distance between points, for example), I cannot select a point of these CSYS objects. I can't place a point at the origins, because they aren't selectable. I can't even place a datum CSYS at these CSYS objects, because they aren't selectable.
I can do Information on them and I see that they have an origin in the Information window that pops up. But short of copying and pasting these coordinates (which is extremely cumbersome and error-prone), is there a way I can reference these points?
