rteja
- Aug 19, 2018
- 12
I want to submit a report verifying the pull out strength of chemical anchor bolt installed on a masonry wall made of hollow concrete blocks.
The HILTI software has a provision for this, but only for a few pre-defined hollow block geometries. It doesn't allow for customization of brick size.
My hollow brick face thickness is around 80mm, but the required anchorage depth will be more than that.
How can i calculate pull-out strength of a chemically fixed anchor in this case?
I Appreciate if you can give me any references or sample calculations for this.
