Hi, can someone assist me with a basic pulley ratio setup?
I have a 1500 rpm motor (shaft dia. 24 mm) and want to reduce this speed to @370 rpm.
My question is: If I add an 85 mm pulley onto the drive shaft of the motor will this reduce the rotation by 1:3.5 before I look at the end drive pulley?
Cheers
Cheers
