Cisnerjo1973
Aerospace
Hello !
I have a question for the experts, is there any amount of layup pulls (usage) for a composite laup tool to start getting weak or to present internal leaks? I heard years ago that usually a fiber glass layup tool can last between 60 up to 100 pulls, but also it depends the temperature and the way people handles the tool. Is there any specific amount of pulls that could say enough parts are built a new tool must be made.
We have a fiber glass tool that its worn out and we are still making sandwich parts over it (two plies of prepreg-honeycomb core- two plies of prepreg), but the top coat surface from the tool has already too many pin holes that are transfered in to the part, besides that on the bag side of the part we locate a press pad (template) since the customer also request a good bag side surface pretty much same as tool side, unfortunately the same results are observed on the bag side even we the template does not has that pin holes situation, I didnt know this issue could also go up to the bag side too is that possible? Basically we are seeing either pin holes but also white spot areas pretty much as delamination where we cant see the honeycomb core due the white spots. The tool is loosing 7"HG in 5 minutes this is an indication of problems during cure cycle. I bagged the tool and placed it under vaccum but with no prepreg or material at all except the bagging materials, placed the tool under 280°F to check if the temperature could increase the leaking I monitored the leak and it only lost 1"HG during the cure cycle, maybe with prepregs it might behaved completely different, unfortunately I cant make them to made a new tool thats why I'm posting this and asking for the expert people support.
Thanks a lot !
Thanks a lot !
