Mark Suplee
If I have 2 pumps discharging into a common header and a pulsation dampener installed in the header between where the pumps tie into the header (upstream of pump 1 but downstream of pump 2). I assume this will still have net + effect on pump 2 discharge but presumably less efficiently. Does anyone have a qualitative estimation of whether this an ok situation. Small chemical dosing pumps 60 psi max 8gph
