NickParker
- Sep 1, 2017
- 454
The pump performance datasheet is attached below. I'm not sure which is the Pump BkW (The Power which pump requires from the Motor).
I'm asking this because, as I want to reduce the loads in the "Load List" so that I can optimize the transformer rating. I have several pumps from the same manufacturer, so considering the correct BkW will considerably reduce the total loads.
Asked this to the pump vendor, but it seems it would take some time to receive the reply, hence asking here.
