puckman31
- Sep 20, 2009
- 21
We have a system, hot water circulating through 4" lines with 4 pumps with 10hp motors . Only 1 motor / pump working at a time. The hot water is circulating through all the pumps even thoug they are not running . Is this a bad design for the non running pumps because when the water passes through the pumps it makes a lot more noise than going through the running pump.
the pumps are in pairs at differrent locations of the systems.
