pump design
mengbly
QA
Hello there
can you please help me in providing the bellow information for standard chilled water pumps built as per HI Institue
1. What is the advantage of endsuction pumps over split case pumps
2. What is the advantage of split case pumps over end suction pumps?
3. when and where are split case pumps prefered ? and when the endsuction?
4. what should be the first preference when selecting the design ( End suction or split case)
also if a comparison of inline pumps if given will be help
tks
1. cheaper, one mech seal
2. more flow, lower npsh requirements, less radial laoding on shaft, easier maintenance
3. splitcase are for high flow, low head situations, very dependable, fire pumps
end suctions are cheaper per HP usually, and much more plentiful in selection, used for everything under the sun.
4, See the above.
Mengbly,
This post is really a request for a book…
With some specifics - capacities and heads – you will probably obtain replies that will address your application.
