bb1974
- Apr 30, 2018
- 3
Sir,
i have a vertical single stage water pump . The pump driver motor was running a with 82 amps but soon after the pump overhaul the current increased to 90 amps. All pump gears are very smooth. But I have removed suction strainer . Is there any relation between this with the performance of the pump. thank you
