LAsludge
Chemical
- Dec 27, 2005
- 28
I have a recurring failure problem with the packing on a high pressure pump. The fluid is pretreated with iron salts in an upstream process. The fluid is then screened to 1 millimeter but I suspect that some fines are getting through and ruining my seal.
The pumping cylinder is made of stainless and the piston is ceramic. The fluid is a well mixed organic slurry at about 5% solid contents. The organic solids are not a problem but the iron certainly would be a problem.
Question...
How much filtering do I need to protect this pump?
I'm thinking of a magnetic filter to focus on the iron grit. Does this make sense and can someone educate me about magnetic filters?
Question...
