One of the centrifugal pumps(30gpm/100ft head) in my facility is facing many seal failures. This pump pumps 200 deg F water from a OPEN TANK with 4' static head.
Is Surface pressure equals vapor pressure here??
The suction pressure reads 20 - 40 inch water( fluctuates a lot) and discharge pressure reads 40 psi. If surface pressure equals vapor pressure( 11.5 psi at 200 F), then
NPSHa = 11.5 - 11.5 + 1.7(4' static head) - 1psi(Hfs) = 0.7psi which is equal to 20 inch water. Are my calculations right? Thanks for any help.
