Pump recommendation for a custom transformer oil cooling system
Rokkit43
I need a pump recommendation for a custom transformer oil cooling system that is relatively smaller than a typical industrial transformer or locomotive tk. It is a 900 gallon rectangular tank requiring only 40 GPM at 75 FT, SG = 0.95, Viscosity = 34 @ 40˚C (mm2/s), Fluid = Synthetic Ester dielectric oil. The pump should mount on top of the tank lid. Current pump is a Polypro Vertical Mag Drive Centrifugal. We experience electrical arcing inside the pump due to high fluid velocity. I would prefer to switch to a PD pump (gear or vane) but I am having problems finding one that is not too large and heavy for this application, (current Renner pump is 1.5” flanged and weighs only 65#). The Viking Model AK493 meets the required flow but is a big heavy 3” pump, for example. See attached for more information.
 https://files.engineering.com/getfile.aspx?folder=3ab42aac-6786-436b-8eb7-b4fe54348d5b&file=HVCM_Transformer_Oil_Cooling_Application_ORNL_SNS_Site_2.pdf
Is your pump available with a conductive plastic construction? If conductive plastic components are available for your current pump that would provide a bolt in solution.
Edit: I see your pump is available in stainless steel. That would also solve the problems.
Unfortunately I am told that this pump is not available in either stainless or a conductive plastic. Per Renner Engineering "Renner does not prefer to change the materials of construction to conductive non-metallic or a metallic material as it will affect the efficacy of the magnetic coupling through the separating can and likely require a larger motor. It is also an area of which they have no experience and much design and testing would be required". I agree this would be the ideal solution. Thank you for responding.
I'm curious about the original specification of a plastic pump for a non-conductive fluid. This is highly unorthodox. If your requirements were clear and this is the pump that was specified I would have some serious questions for the manufacturer.
