moiz19670309
- Jun 15, 2013
- 30
We have a simple Centrifugal pump with 150 m3/hr flow vs 185 feet head. It has a simple 5 inch vertical suction pipe with a vertical length of 12 feet. Than a long radius elbow than horizontal 5 inch pipe 8 feet long. It then has a concentric reducer from 5 inch to 2 1/2 inch pump suction port. By the way the pump also has a 5 inch foot valve. The submergence above foot valve is 3 feet. We are facing problems with start up. When we start this pump after the priming. Their appears to have sound as if small blasts are being taken place in the pump. This happen for 3 to 4 minutes after which the pump runs quietly.
I think the problem is with the concentric reducer air traps in the area above concentric reducer. The air takes time to get out of this area after which the pump works smoothly. I am right. Should i change the concentric reducer with eccentric reduce?
Guidance required ....
