garciaf
- Jun 12, 2016
- 64
Here´s my issued:
The discharge line that is installed is 4 inches diameter 2000 m in length, from the ship to Tank
The tank maximum level is 12 meters
Sea level to the level of tank 8 meters
The pumping liquid is Gasoline
Data from software:
Flow: 200 gpm
Diameter of suction: 4 Inches
Diameter of Discharge: 4 Inches
Suction Pressure: -5.21 psig
Discharge pressure: 52.43 psig
Pump Head: 56.37 m
Pump NPSHa: 1.452 m
These are the data from the calculation with Pipeflow Expert
When I am going to select the pump.
I find a pump curve that match, but the issue is the following:
The Suction of the pump is 3 inches and the discharge is 2 inches.
the calculations done with the software both the suction and discharge are with 4 inches. See image attached
When I change the suction line for 3 inches in order to match with the suction flange pump, the NPSHa is lower that NPSHr which is not possible due to cavitation.
My question is the following:
Can I keep the same suction line with 4 inches and do a reduction 4X3 in order to match; also the discharge line from 2 to 4 inches because the line installed is 4 inches.
How this can affect the pump, is this Ok.
Please help.
Thanks for you time
Data from software:
Flow: 200 gpm
Pump Head: 56.37 m
Pump NPSHa: 1.452 m
Please help.
Thanks for you time
