We are having problems with some of our wet well submersible mixed flow (shrouded) vertical sewage pumps.
Pump end bearings are failing and the seals are failing. Motor end bearings are also failing.
The pumps are running out on the curve when they start for about ten seconds or so - a short period but they start quite often and it soon adds up.
Also the pumps are "turbining" when they are switched off -this is required as the pumps are in a 20m sump, therefore vacuum breakers are needed in the valve house.
I am convinced that the increased radial thrusts known to happen to the right of BEP are causing a problem during start up.
My intuition (not been calibrated for a while admittedly) tells me that during the turbining phase the axial thrust may reverse. Obviously it would need to overcome the pump dead weight. My main concern here is that the bearing arrangement in this particular pump only takes thrust in the downward direction.
However I cant find any calcuation for thrust during this operation (Ive looked at Sulzer, Karrasik) or even refernce to the possibility of axial thrust changing direction.
Any comments or suggestions greatly appreciated
