Isaacnewton4
- Nov 21, 2017
- 5
I trust you are well.
I have just started at this big boiler making company and there is a problem we are trying to fix with regards to water level in the boiler. We are looking into installing a differential pressure cell across the pump, such that the head of the pump can be changed as the boiler pressure modulates. This is to ensure that pump head is always greater than the boiler pressure so that there is flow at all times when required. I am working on a 11bar boiler as the test case. Feedwater tank is usually 3m tall. I do not know how to proceed from now on. I will appreciate any help on this
IsaacNewton4
IsaacNewton4
