Ronak_Patel
- Jul 26, 2021
- 43
I`m using SI units in PVelite .
As per ASME Div 1 , mandatory appendix 2 (2-3) value of cb=0.5 for US Customary and cb=2.5 for SI calculations .
While Reviewing Pv Elite design calculation of flange i found this ,
Gasket Contact Width, N = (Go - Gi) / 2 = 13.000 mm.
Basic Gasket Width, bo = N / 2 = 6.500 mm.
Effective Gasket Width, b = Cb sqrt(bo)= 6.425 mm.
if i use cb=2.5*sqrt(6.5)=6.37 , as such its not much of difference but which value should be followed?? ..
pvelite is first converting bo in inches then calculating b and converting it in mm to get 6.425mm
