Feb 5, 2024 1 #1 Europeeng Mechanical Jan 24, 2024 6 0 0 NO Hi, How do I apply the nozzle loads at the Nozzle end in PV-Elite? I can`t find this option.
Feb 29, 2024 #2 jt1234 Mechanical Nov 17, 2022 78 0 0 US Too bad no one answered your question. There is no such option to apply loads at the face of flange, neither COMPRESS. There is no such need unless you are doing UG-44(b). Upvote 0 Downvote
Mar 1, 2024 Thread starter #3 Europeeng Mechanical Jan 24, 2024 6 0 0 NO Hi, Yes, it is possible to apply the load at the nozzle end. In the setup menu there is a option for this. Upvote 0 Downvote
Mar 3, 2024 #4 XL83NL Mechanical Mar 3, 2011 3,043 0 36 NL can you show a screenshot? Huub - You never get what you expect, you only get what you inspect. Upvote 0 Downvote
Jul 7, 2024 2 #5 Solar_Greed Mechanical Jul 7, 2024 1 0 0 IN Go to configuration > then Nozzle > there you will see 3rd option on top for Nozzle loads to be applied at the ends of Nozzle. It was available in previous versions too. Previously it was in Load Case tab. Upvote 0 Downvote
