Dear Gentlemen:
I am planning to use U-PVC pipe in lieu of DI pipe for a sewage traetment plant in hot climate area. I am aware that there are pressure rated U-PVC pipes and C-PVC pipes can be used.Also, U-PVC cannot be exposed to sun where as C-PVC can be.
In addition to the above characteristic nature of the PVC pipe, Is there any other problem which I need to consider if I use U-PVC pipe in lieu of Ductile Iron pipe?
Your suggestions are greatly appreciated.
JR
JR
