Thank you r6155.
1. I observe that
as per EN 13445 10.5.3, "generally maximum actual PWHT temperature
shall be at least 30°C below the minimum actual tempering temperature ...."
Where as as per PD 5500, 4.4.6.3, "the PWHT temperature shall be at
least 30 °C below the maximum tempering temperature,..."
There appears difference in the above codes and former one appears logical. Please correct me if I am wrong.
2. What about difference between Lower critical temperature and Tempering temperature. How much minimum difference is recommended.
