Reference to Table 331.1.1, only PWHT parameters (soaking time, soaking temperature) where provided based on applicable thickness selected by designer.
However, Table 331.1.3 provides exemption to mandatory PWHT requirements provided preheat of 95 deg cel maintained during welding when nominal welding thickness exceeds 25mm.
Based on above does it mean that PWHT is not applicable where weld thickness is less than 25mm.
