Hey all... I have a simple question, I think.
I have a small dead cavity that is only 0.030" wide by 1.5" diameter. The only leak path would be under bolts/washers (this bolts (3x) are small 1/4" dia or less). How much pressure should I expect in that cavity, if the head of the bolt area is at 2000 psi? I surveyed my colleagues and get a mix response (almost a 50/50 split). Some say little pressurization, others say full 2000 psi. My thinking is that the bolt/washer interface provides some resistance/sealing (though a bad seal).
What do you think?
Thanks in advance.
s.
What do you think?
Thanks in advance.
s.
