QUEST_7850
Military
- Jun 7, 2023
- 1
Good afternoon. Not sure I'm on the right website or forum for this question, so if not, please point me in the right direction.
I recently located a structure made of concrete blocks sitting in the woods. I've been told that it's 20 years old. It has no roof or floor. No one knows what the ultimate plan was for it (garage, English basement, etc). Apparently, they got part-way and abandoned the project.
The walls show some cracking but I'm not sure if it's weathering or something else. It's a square with walls 30 feet in length and around 10 feet high. There is no evidence of a Footer. In fact, it actually looks like the walls were erected right on the ground. The soil here is very rocky with very little topsoil. There is no evidence of any attempt to help water drain away from the structure. Trees have grown all along the walls, both inside and out. It's on the side of a steep slope so water flows down-hill towards the structure. Two of the walls are lower than the ground. Those two walls are separated from the dirt by a deep trench. Water flows into the trenches and collects at the bottom. Someone dug a fire pit in the center of the structure. Water flows into the pit and I've been told it seeps out towards the walls.
I've attached two photos showing the structure and trees around it. Attached is a diagram showing that two walls have a trench on the outside where water and debris collect. Finally, I've attached a diagram showing how I think water flows and seeps around the walls.
What I'm trying to understand is whether this structure can be saved. If several think it can be, then I'll hire a local enginner to check it before I make an offer on the place. But I don'w want to waste an engineer's time and my money if you all think this thing is beyond salvage.
So what do you all think . . . is this structure salvageable?
If so, can someone just take a wild guess at potential repair costs? Are we talking around $1000, $5K, 410K, $20K
Other questions:
1) Since the structure has no load on it like walls, flooring, roof, furniture, etc, how can someone tell if it's still solid enough to build on?
2) If there are no Footers or if water has been getting at the Footers for 20 years, are those walls still safe to build another story or two on?
3) Might tree roots have damaged the Footers/Base beyond repair?
4) If an engineer wanted to examine Footers/base . . . would he have to look at both sides of the footer/Base . . . inside and outside? If so, how would you check the Footers/base on the outside of the two walls that have trenches next to them? Would you have to dig them out?
Thanks in advance
JQ
Other questions:
Thanks in advance
JQ
