Hi everyone. I've got a bit of a philosophical question regarding shear failure of bolted joints. It is often common practice in my industry to check whether shear tearout, fastener shear, or bearing stress is of concern in a design. However, the general understanding of the behavior of bolted joints in shear indicates that until the joint slips, all the load is taken by friction. Say that the joint is predicted to slip, eventually the bolt(s) will engage their clearance holes in shear. However, given manufacturing tolerances, isn't it likely that only a limited number of fastener will engage in shear (bottoming out against its hole) before the others, depending on the direction of loading? In theory, a "zippering" effect could be observed where one fastener fails followed by others subsequently, since the load is taken mostly by one until it fails, then the next, etc.. This of course assumes that the joint design does not permit load redistribution to other fasteners before failure. In other words, using nominally predicted shear forces from a FEM or other hand calculation would not be appropriate for estimation of shear failure in this case, despite what is typically done in stress calcs. Curious what others think and how you all have handled such calculations in your designs/analysis. Thanks!
