Question about nxopen therms
Ehaviv
Computer
Jul 2, 2003
1,012
Hi
I found this table in the internet in this url
what is the difference between: Instance and Component Part
Component and Occurrence
Prototype and part
Tag
is being used for the old term EID (Entity IDentifier) and for
the new term object identifier. A Tag identifies an
object in the NX database. The objects are not limited to
geometrical objects, but can include parts, instances, and occurrences.
用在旧的对象标识和新的对象标识之前。在NX数据库中,一个标识定义一个对象。对象不仅限于几何对象,也包括parts(部件)、
instances 和 occurrences。
Piece Part
This is the lowest level part in an assembly; it contains geometry
and features that represent the physical object, but no components.
装配中对底层的部件,包含物理对象的几何体和特征体,不包含components(组件)。
Occurrence
When several parts are brought together into an assembly, the parts and their objects are not
copied into the assembly part. Rather, the parts are loaded into memory, and part occurrences
of those parts are put into the assembly part.
当若干parts(部件)装配在一起时,这些parts(部件)和属于他们的objects(对象)不会被复制到装配部件中。而是将部件装入内存中,这些部件以
part occurrences形式显示在装配部件中。
Object Occurrence
For each object in the piece part, an object occurrence of that object is made in the assembly part.
对于每个piece part中的每一个对象,以object occurrence 形式显示在装配部件中。
Instance
This is the term used to indicate the placement of a component part within an assembly
part. For each Instance, a Part Occurrence is displayed in the assembly part.
表示在装配部件内部的一个component(组件)的位置。对于每一个instance(实例),装配部件中都会显示一个part occurrence。
Multi-level
Assemblies can be multi-leveled. For example, an automobile can consist of the body and
two instances of an axle assembly part, which itself consists of an axle and two instances
of a wheel assembly part, which itself consists of .... etc. In these cases, each
Instance can have more than one associated Part Occurrence.
装配可以是多层次的。例如,一个汽车可以由车身和两个轴装配部件的实例组成,而轴装配部件又是由轴和两个轮子装配组件组成,
如此等等。这种情况下,每个instance(实例)可以有多个关联的part occurrence。
Component Part
This is the usage of a part within an assembly, at a particular location and orientation.
A component may be a sub-assembly consisting of other, lower-level components. Each component
in an assembly contains only a link to its master geometry. When you modify the geometry of
one component, all other components in the session using the same master
update automatically to reflect the change.
在一个装配中,表示特定位置和方向的部件。一个组件可以包含由底层的部件或者其他组成子装配。
装配中的每个组件只包含主几何体的一个链接。当你编辑一个组件的几何体,会话中使用相同(部件)的组件将会自动更新。
Old (V9) style components are stored in the Database as Type 63, Subtype 0.
New (V10) style components are listed as Type 63, Subtype 1.
Prototype
This is the master geometry to which an occurrence is linked. In the case of a part
occurrence, it is the piece part containing that master geometry.
原型:这个是一个被链接的occurrence的主几何体。对于part occurrence来说,它就是包含了主几何体的piece part。
Reference Set
This is a named collection of geometry from an NX part that may be used to simplify the
representation of the component part in higher level, large, complex assemblies. Whenever
the name of a reference set is passed in to a routine, if the string is NULL or blank, the
whole part is used. If the string "Empty" is used, the empty reference set is used.
Displayed Part
This is the part that is being viewed in the graphics window. It can either be a piece part
or an assembly. The displayed part must be fully loaded. A partially loaded part
can be made the displayed part by opening it.
Work Part
This is the part whose geometry or assembly structure is being modified. The Work Part can
be the same as the Displayed Part or any component of the Displayed Part if it is an assembly.
The work part may be partially loaded, but must be a member of the assembly which is the
displayed part. Only objects of the work part may be edited.
Object occurrences can not be edited, but they may be queried to find their data.
With translation
Code:
[b]Tag[/b]
 Used before the old object ID and the new object ID. In the NX database,
 an identifier defines an object. Objects are not limited to geometric
 objects, but also include parts nstances with occurrences。
Code:
[b]Piece Part[/b]
 The underlying components in the assembly, including the geometry and
 features of the physical object, without components (components)
Code:
[b]Occurrence[/b]
 When several parts are assembled together, these parts and the objects belonging to them are
 not copied into the assembly part. Instead, the parts are loaded into memory, and these parts are
 The part occurrences form is displayed in the assembly part
Code:
[b]Object Occurrence[/b]
 For each object in each piece part, it is displayed in the assembly part as object occurrence
Code:
[b]Instance[/b]
 Represents the position of a component inside the assembly part. For each instance,
 a part appears in the assembly pa
Code:
[b]Multi-level[/b]
 Assembly can be multi-level. For example, a car can consist of an example of a body and
 two axle assembly components, which in turn consist of a shaft and two wheel assembly components.
 So wait. In this case, each instance can have multiple associated parts occurrence
Code:
[b]Component Part[/b]
 A component that represents a specific location and orientation in an assembly. A component
 can contain components that are composed of the underlying components or other components.
 Each component in the assembly contains only one link to the main geometry. When you edit
 the geometry of a component, components that use the same (component) in the
 session are automatically updated.。
Code:
[b]Prototype[/b]
 Prototype: This is the main geometry of a linked exception. For part occurrence,
 it is the piece par containing the main geometry.
Code:
[b]Reference Set[/b]
Code:
[b]Displayed Part[/b]
Code:
[b]Work Part[/b]
I don't think it can be explained in a simpler way. :)
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
Hi Ronald and thank you.
Do these therms can be shown on assembly
Novigator.
I'm also readed the nx open car example
And I think I understood it.
But still confused about components, part occurrence, and insurances.
It seems all the same thing
