Hello, I need to install this piece of equipment (about 11kg) on a round face with 4 bolt holes (diameter 25 mm, diagonal distance between hole = 200mm). The equipment I have come with 4 off 15 mm holes, same diagonal distance 200mm. How do I bolt the two together given the large different hole sizes? Thank you.
